Same as the side stays
Since no one has given you an answer yet, I'll throw my two cents in. On my 25, as well as with my previous V2-22, I first adjusted the side stays equally to have the mainsail halyard hanging approximately 3 inches behind the mast. Then I would take-up the slack on the backstay. Lastly, I would adjust the forestay to be equal in tendion to the sidestays. Then recheck the tension of the backstay. If the tension is correctly set, the downwind sidestay will have just a bit of slack when the boat is heeled. No science involved...just trial and error.
