C
CO Editorial
How often do you change your zincs?While this question generally addresses the zincs you install on your prop shaft, we should also discuss zincs used in your engine or cooling system, too.Is the replacement cycle consistent, or does it change from year to year? Have you found any difference in location, brand, size or type you apply?Share your most corrosive opinions here, then vote in this week's Quick Quiz toward the bottom of the home page.
