Problem with your power train
13 horses should drive a Bristol 27 well over 5 knots with a two bladed prop at cruising RPM, and light air/waves. Our old 8 horse Yanmar will drive our 7,000 pound '77 h27 with a 2 blade prop at 4.5 knots all day.So I suspect that you have a problem somewhere! If you are growing a big beard on your bottom, what is one possibility. If not, and if 2400 is the cruising RPM for your Westerbeke, and you are making those turns, then we have to focus on the prop. It may have the wrong diameter or pitch for your engine, or it may be seriously out of true. In any case you need to choose a good prop shop to do the numbers for you. If you are interested in a new prop, pick a shop that offers the prop(s) you are interested in. Retruing our prop, and adding a tip conversion added a half knot to our cruising speed at a cost of $175 at Alameda Prop.In any case, you will need to find out the pitch and diameter of your prop. The data was stamped on our prop, and can be read using a diving mask with the boat in the water. Visual inspection usually cannot detect alignment problems. So you will probably have to pull the prop and get it to the shop to really figure out what the problem is.DavidLady Lillie
