How much mast ra
Stan
How much rake should you have in a 88 catalina 22 with split backstay and equipped with a tensioner. Currently mine is set up with about 1.5 inches of bend using the front shrouds to pull it forward .
F
Frank Corpus Christi, Tx
Mast Rake
According to the North Tuning guide the Mast rake should be 6-7". It should not matter what type of backstay adjuster you have. Since you have a mast head rig you can not "bend" your mast to an appreciable extent using the backstay. What you can do is tighten the forestay with your backstay for the proper sail trim of the jib for the conditions. The prebend in the mast set up by the shrouds should also be set according to your sailmaker. The more bend the flater your sail and less power. Frank
