Bottom paint decisions
Steve, Everyone has there own preference tothe type of bottom paint they use and methods of application vary, so I'll just state my mind and leave it to yourown judgement. 1st off for the type of boat you have and the seasonal useage you have described you should consider using an ablative type bottom paint. This paint will go a long way towards solving some of the up coming headaches you are going to have when time to scrape off the build up aquired over the past many seasons. Unlike a conventional paint, this paint remains effective while hauled out on the trailer. Just wet it down and give a light scrubbing with a scotch brite pad before launching, and the paint is just as effective as it was when you hauled out at the end of the last season. Checkthe west advisor in their catalog for a more detailed explanation. I use Pettitacp-50 on my boat today and have gone as many as three seasons without recoating! The great part is when it is time to repaint there is not anywhere near as much sanding to do! The removalof your existing paint will be a big chore, but even if you stick with that coventional paint your going to have to strip it down and start over again before to long anyway. Check out that West advisor and check for other repliesto your post. I think there will be others to back me up later. Good Luck, Bucky Sherman
