Bob Early
My boat ( Hunter 27 '1978) has several hardware issue, involving screws and bolts. I am very new to this type of fiberglass and epoxy, but cautiously enthusiastic. After reading the section “Installing Hardware” in the West System 002-550, I still have questions.I want to mount overhead grab rails (probably teak with multiple holds), but am unclear as to how much weight the hardware will hold with the epoxy base. It seems like the core is about an inch thick (It’d be nice to have a non-invasive means of measuring the thickness before drilling the holes.)Would the “wetted sponge” idea work better in this case? Additionally I’d like to add a couple of mid hull cleats, but the interior seems completely inaccessible without a major project. Is there a reasonable way to make the holes in the side decks, secure the mounting bolts with epoxy and maintain strength? (I have seen those “pop up” cleats and they seem like they would be good for this application, but require about 2 inches of space and of course, secure mounting.I realize your answering questions about using West System products, but whenever I want to mount some hardware or add stuff to the boats fiberglass, I always find my self asking the question: How much non-static force will this fiberglass take, before I need to concern myself with failure and possible serious damage? Is there a reasonable method of determining the strength or force that, for example, the foredeck can take by adding more hardware to it?Thanks,Bob Early
