How long should they be?
6
Oday 26 Sheboygan, Wi
I need to replace most of my running rigging. I don't have a list of running rigging diameters or length. I don't want to just replace what is currently there because what is there was on the boat when I got it and not all the lengths and diameters seem correct. Can anyone help?
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Rudy at D&R Marine can set you up with everything you need without any of the guess work.
http://www.drmarine.com/
caguy
Sep 22, 2006
4,004
I don;t know if this helps but I just set up my sheets for the asymetric spinnaker. I had read that the length needed to be 1 1/2 of the boat length, but I wasn't certain so I bought 100 ft of 1/4'' from Minnie's for $25. I did my own eye splices with some fids that I made from scrap ss tubing. There are some good videos on youtube that show you how. There are also some great books. Once you've done your first one the rest come much easier. The diameter of the jib and genoa are 5/16''.
The point is you can custom make your own for a lot less.
caguy
Sep 22, 2006
4,004
I don;t know if this helps but I just set up my sheets for the asymmetric spinnaker. I had read that the length needed to be 1 1/2 of the boat length, but I wasn't certain so I bought 100 ft of 1/4'' from Minnie's for $25. I did my own eye splices with some fids that I made from scrap ss tubing. There are some good videos on youtube that show you how. There are also some great books. Once you've done your first one the rest come much easier. The diameter of the jib and genoa are 5/16''.
Jun 2, 2004
1,944
Oday Day Sailer Wareham, MA
For 1977-85 O'DAY 23 (figures from 1979 O'DAY specs)
Main Halyard: 5/16" x 56'
Jib Halyard: 5/16" x 57'
Mainsheet: 3/8" x 53'
Jib Sheet: 3/8" x 40' (tied through jib clew (20' per side)
Mainsail Outhaul: 1/4" x 9'
Boom Downhaul: 1/4" x 3'
Topping Lift: 1/4" x 27'
Genoa Sheets: 3/8" x 60' (tied through clew, 30' per side)
All lines would typically be of Double-Braided Dacron (Polyester).
estopa
Feb 27, 2008
182
Oday 222 Milford, CT
Nice how would i get this info for a 222?
Jan 24, 2005
4,881
Here are the running rigging dimensions for the 1986 O'Day 222 George.
RUNNING RIGGING
O\DAY 222
Z Spar
Specifications beginning with Hull No. 69~
11-18-86​
TITLE SIZE TYPE LENGTH A END B END EXTRA INFO
Jib Halyard 5/16 XLS-Blue 44' 93-42 Burn
Main Halyard 5/16 XLS-Red 57' 93-42 Burn
Main Sheet 3/8 TRO-Red 42' SK4838 Spliced In Whip
Jib Sheet 3/8 TRO-Blue 35' Whip Whip One
Reef 1/4 TRO-Green 21'6" Burn Burn
Outhaul 1/4 XLS-POE 13' Burn Burn​
Topping Lift 1/4 XLS-POE 15'6" Eye Burn
