How long should it take to make hot water when running the engine?
I have a Kuuma water heater on my 1988 C30 which is plumbed to the engine through the thermostat bypass hose but it is REALLY SLOW to heat. I tested it yesterday with a digital non-contact thermometer. The inlet hose from the engine was about 140º but after a 40 minute run, the hot water coming out of the water heater was only 6º warmer than the water going in.:cussing:
The really weird thing is that I have a RedDot heater that is in this same loop that uses the engine coolant after it leaves the water heater and it heats the cabin quite nicely. It seems like the heat exchanger in the water heater exchanger has insulation around it.
