How I Added a Gas Spring to My Selden RodKicker Boom Vang
Sep 22, 2021
293
Hunter 41AC 0 Portland, OR
When we were looking at the Hunter 41DS that we eventually bought, I assumed that the rigid boom vang it had was fully operational. It turns out that this boat, and a lot of other Hunters I gather, had a boom vang without a gas spring making it only marginally more useful than a traditional block and tackle boom vang.
I checked into the gas spring kit, part number 308-072-04 for a Selden RodKicker 20, which costs upwards of $650. The kit consists of a gas spring, a lower block and a spacer tube. Some searches turned up the specifications for the gas spring that I needed and I found a very close match at McMaster-Carr, p/n 4175T36 (stainless steel) or p/n 9416K52 (painted steel). Both are available with extension forces ranging from 200# to 550#. For my boat, a 2500 Newton gas spring is specified and the 550# unit is equivalent to about 2200 Newtons. The painted steel one in the 550# version wasn't in stock so I opted for the stainless version at a cost of just under $150 including shipping.
I decided to make my own lower block using some scrap UHMW that I had from a previous project instead of buying the Selden part for $24. However, I wanted to know for certain what the configuration of the spacer tube was so I bought the 40mm dia. x 580mm Selden part for $21.00. It turns out that the spacer tube isn't anything special - just some 40mm diameter aluminum tubing with a 1.5mm (about 0.060") wall. However, I didn't like the idea of the thin raw ends of the spacer tube transferring the extension force of the gas spring to the lower end casting and the lower block so I made some plugs out of aluminum that were pressed into both ends. You can see the modified spacer tube in one of the images below.
One of the issues that arises when fitting the gas spring is to calculate the appropriate length of the spacer tube. I wanted the upper tube to bottom out on the "buffer bearing" at the top of the lower tube before the gas spring reached the end of its travel under compression. In one of the photos below you can see the parts laid out as they would stack up when assembled. I calculated that a 20" spacer tube length would allow 10-1/2" of the 12" travel of the gas spring to be used. This allows some additional compression in case the vang is slightly over-compressed.
Normally, you wouldn't need to drill out the rivets and remove the lower end casting. In my case, however, I wanted to see exactly what the inner end of that casting looked like and, further, I needed to replace the buffer bearing that was damaged due to over-compression by a previous owner. Since the wire rope goes through the buffer bearing, I needed to disconnect the end of the wire rope from the casting to allow installation of the new buffer bearing.
The photo below shows the parts layout of the RodKicker 20. The casting at the left attaches to a swivel on the mast near the base and the casting on the right attaches to the boom. The block and tackle (not shown) attaches to the lower casting and the eye of the wire rope. The lower casting is fastened to the lower tube by three 1/4" blind rivets (two stainless, one aluminum). The black plastic piece on the right end of the larger tube is called a "buffer bearing". Its purpose is to act as a spring when the vang is fully compressed and also as a bearing for the inner tube to ride on.
The photo below shows the lower block that I made out of a block of UHMW. Both ends of the gas spring have M10-1.5 threads and the upper end threads into the end plug of the inner (upper) tube while the lower end (the piston) normally threads into a second end plug oriented in the same direction as the upper one. The substitute lower block that I made is about 1-1/2" thick and shaped for a slip fit in the outer tube. It has a threaded insert pressed into it made of aluminum bronze. This insert has a T shaped profile so that the insert can't be pulled out of the block.
Edit: the material used for this block was actually Delrin. I had some left over from when I made new bow rollers for the anchor. I think that either UHMW or Delrin (or even aluminum) would work fine for this.
This photo shows the finished spacer tube. The end plugs extend into the tube about 1/2" with an overall length of 3/4". The were turned so that the larger O.D. is slightly larger than the 40mm tube while the smaller O.D. was turned to be a 0.001" press fit into the I.D. of the tube. The spacer tubes for the RodKicker 10, 20, and 30 are 31mm, 40mm and 50mm diameter, respectively. You could use some 1-1/2" diameter aluminum tube (about 38 mm) for a RodKicker 20 if you also add the end plugs like I did. A 1-1/4" tube would probably work for the RodKicker 10 while the RodKicker 30 would need a 2" tube.
The photo below, which I got from one of the suppliers' websites, shows how the gas spring kit is installed inside the boom vang.
My total cost for installing the gas spring was under $200 (compared to $650 for the kit). If I hadn't had the materials in my scrap bin to make the lower block and the spacer tube end plugs it would have been more but still less than $250. I installed it today and it works great.
Below, I've listed the Selden part numbers for the various pieces you would need as well as a few possible sources of those parts. The biggest issue will be determining the strength of gas spring you need. In my case, a 41DS with a furling main, the 2500 Newton size was recommended. You might be able to find out from one of the suppliers which gas spring kit you should buy for your boat and from that you can determine the stength of gas spring you need.
Selden RodKicker Parts
RodKicker 30
319-588 End Plug
512-141 Spacer Tube, 50mm dia. by 640mm
512-138 Spacer Tube, 50mm dia. by 760mm
RodKicker 20
319-587 End Plug
512-142 Spacer Tube, 40mm dia. by 350mm
512-139 Spacer Tube, 40mm dia. by 460mm
512-137 Spacer Tube, 40mm dia. by 580mm
RodKicker 10
319-586 End Plug
512-140 Spacer Tube, 31mm dia. by 220mm
512-136 Spacer Tube, 31mm dia. by 335mm
Possible Sources:
Vela Sailing Supply
Fisheries Supply
Toad Marine Supply
1,748
Thanks! nice job! I've been thinking about doing the same thing on Escape but haven't had time to dig into it
Jul 8, 2023
2
Hunter 38 Kent Narrows
Could you explain how you disconnected the lower end of the rodkicker (as depicted in your first photo)? I have a 2005 Hunter 38, which also has a damaged buffer bearing (see photo). To replace it, I'll need to free one end of the rodkicker cable. The upper end of the cable won't go through the sheave because the cable eye is too large. So it seems my two options are to either (1) remove the sheave, which requires somehow removing the sheave pin or (2) detach the lower end of the cable, which requires removing the lower end fitting.
I've banged on the sheave pin but it doesn't pop out easily and I'm concerned about damaging it. Based on your photo, it appears removing the lower end fitting is possible but it isn't clear to me how to do so. Is there just a pin holding the end fitting in place, which can be tapped out with a nail or is some other tool/method required to disassemble it?
Sep 22, 2021
293
Could you explain how you disconnected the lower end of the rodkicker [...]
You have to drill out three blind rivets (pop rivets) that secure the lower casting to the lower tube (see yellow circle in the photo). I briefly described this in the fifth paragraph of my original post with additional details in the sixth paragraph. If I remember correctly, they are 1/4" rivets (two stainless and one aluminum). After the two rivets are removed, the lower casting will slide out of the lower tube and you can disconnect the eye in the end of the cable from the casting. Once that is disconnected you should be able to slide the two tubes apart. Of course, you'll need to re-rivet the lower casting once you have replaced parts and re-assembled it. If you don't have a blind rivet gun that can work with 1/4" aluminum/stainless rivets perhaps you can find someone from whom to borrow one.
Likes: bogatron
Jul 8, 2023
2
Thanks for the detailed info and quick reply. This makes perfect sense. I'll just go ahead and buy a blind rivet tool, since there's a good chance I'll eventually be adding a gas spring as well.
Sep 22, 2021
293
I'll just go ahead and buy a blind rivet tool [...]
You might consider the Marson Big Daddy RIveter. They are a bit more expensive but good quality. I bought a used on on eBay for about $75 compared to two to three times that new.
Likes: bogatron
Jun 29, 2009
2
2 28 Centerboard Great South Bay
Thinking about the Rodkicker myself. Only my existing collapsed/moored vang is at 50” and Rodkicker is 55”. Assuming I leave boom tang in same position as it should be because hatch is in line and below the vang does anyone know if that 55” length can be changed? One end removed extrusion cut and reassembled. I will also need the 10 gas strut. O’Day 35 is the boat. Thank you.
Aug 12, 2022
4
I don't own one yet not yet Not yet
Thank you, thank you, thank you!!! This might sound dumb but I have had the hardest time finding information on Rodkickers, specifically which Rodkicker I have. The RD itself is not marked with a model number (at least not that I could find) and the documentation I have is for the 10, 20, and 30. There are some measurements listed for the different models but it wasn't clear exactly what I was measuring. And the Internet didn't specifically list which RD comes on a Hunter 44DS. Knowing that you have a 41DS and the associated Selden rig, lets me know that I have the 30. I have a couple of friends with Hunter 41DSs and their RDs are smaller than mine...deduction says mine is the 30.
I really appreciate that not only did you provide the details of your upgrade but you listed part number AND likely suppliers as well. So again, thank you. There are still a couple of things I'm a little unclear on including the length of the spacer for my application. On my boat the RD, when installed, remains mostly collapsed. I've noticed on the 41DS rigs that the RDs are expanded quite a bit. basically I'm not sure which of the two spacers you listed I should order...hoping the suppliers might have some answers on that.
Aug 12, 2022
4
Given my lack of expertise/experience in cutting and shaping UHMW, $24 sounded like a pretty good deal to me for the end plug/lower block...unfortunately the inflation monster has been working overtime in the Marine industry. Of the three suppliers you listed, Toad was the only one that listed the end cap for the RD30, Part Number: 319-588 and it is $53. Suddenly, learning new skills and making my own lower block sounds like a fantastic idea. Can you possibly provide any details on how you did that and what you used as an exemplar/template?
Sep 22, 2021
293
I have a hobby machine shop so I used my vertical milling machine to create it. However, it could be made using typical homeowner tools - hand saws, power saws, files, sanders and drills. The outer part needs to fit the profile of the inside of the aluminum extrusion and the slot must allow free movement if the cable. Further, the two flat sides need to be reasonably parallel but the distance between them isn't critical. You could start with a slab of Delrin or UHMW say 1-1/4" thick (look on eBay) which would give you the two parallel sides and you would only need to work on the remaining features.
