Most twisted 1X19 wire needs to be 'set in' by stretching when new, stretched a few times until all the wires reach a dimensional steady state with relation with oneanother in the 'twist'. Once that pre-stretching is accomplished the wire remains quite stable. .... unless the wire exceeds its 'yield strength' and is now permanently 'stretched'.
If any of your rigging wire was newly installed, the 'settle-in to final length dimension' may be what you are observing.
Most probable reason for rig length/tension changes include:.
1. If deckstepped mast system the probability that the mast butt wasnt fully settled in its 'socket' when the rig was tuned.
2. deformation of the support structures (rot) of the compression post, and other mast supports; or, if keel stepped rot or other changes under the mast butt support
3. swages that are slipping
3a. swages that have become cracked (slipping), or corrosion is occurring inside of the swage allowing the wire to slip.
4. Rigging screws that are slipping due to cracks in the 'barrel' portion
5. elongation of the clevis or swaged 'eyes' - plastic deformation.
6. rigging screws 'backing-off' by vibration, etc. especially if the rigging screws are not a good 'non-overhauling' design (a poor thread pitch choice).
7. chainplate problems: rot in the knees, chainplate deforming because of gradual 'fatigue' of the metal (brittle + ductile failure), cracks in the chainplate, broken/deforming chainplate attachment bolting, etc.
8. corroded mast butt.
9. gremlins
