Specific to sail setting...
I find that in heavy air (15 knots) and beating into the wind, the boat sails best when the jib is tight and the main is actually a little loose. The natural instinct is to tighten (flatten) the main down in heavy air when beating, but I find the leaving it out a bit with the luff backwinding a little actually makes the boat sail faster and is easier to handle.In reaches and runs I make sure the boom vang is tight so the main doesn't balloon. In shifting winds be very aware of that boom!In heavier air, as the others have said, "reef". The 26 and 260 handle miraculously better, significantly more stable and quieter, when reefed properly. I'll also roll in the jib with my furler, but if you don't have a furler consider having a shock-cord on-hand so you can drop the jib quickly and secure it down if you can't get it off.
