stove
Hi , if it is the origo, (sp???) which is like most, hunters at least our 89 23 has one, and have seen several, is is a non pressurized alcohol stove, you merely remove, the rubber cover, pull out from frame and , fill with alcohol it has a simple sliding flap tykpe thingy that adjusts flame height, just lite and , cook , I know it may intimidate you at first, but it is just a simple wicking type stove, burns neat and clean, make sure it says origio , , lite with match, close cover to extinguish flame, if you have pjroblems email me mmsailor @aol.com good luck Mike B
