Ahoy!
The respectable users of this forum already helped me to explain several mysteries of my second-hand Irwin 41 that I'm getting to know. The puzzle for today is: how is this supposed to work? I'm talking about the reef line system that you can see in the photos attached to the post. Namely, there is a pulley for each line that runs from the cringe on the leech of the mainsail inside of the boom and then there is... right, what is this thing? :neutral: It's a solid metal ring with knurled surface mounted on an excentric axis. In the little schema I show how I use it today: I thought it might be just a simple cam cleat. But then, the pulley doesn't make that much sense... And the knurled surface makes pulling the rope through it that much harder...
I bet many of you have seen this solution already or even have it on your boat. So, what's the secret?? How am I supposed to use it?
Greetings to you all!
Szymon
Szymon
