My boats and bilges
My 23 had an electric pump on board when I bought it, but there's no real 'bilge' to speak of on that boat. The pump wasn't 'hard-wired' to the boat; it was just sitting in a storage compartment and hooked up direct to the battery when needed... I used it once to pump out the rain water that had accumulated in the cockpit locker (and have since fixed THAT leak), and never needed it since. My 'new' 25, on the other hand... I haven't gone over all of the boat's systems just yet; I do know that the previous owner used a sun shower in the head compartment and drained that into the bilge, and I think the icebox drains into the bilge as well. Its pump is on an automatic switch, as the boat lies on a mooring unattended much of the time. I plan to stop the 'shower in the head' practice until I can dry out the bilge and make sure there are no other significant leaks.Plans? I think the 23 is fine the way it is- It has only one through-hull fitting that would cause concern (the cockpit drain), and I have MORE than enough sealant on that, as well as a new hose with double clamping. Not too worried about that one. There are a few 5-Gallon buckets aboard (Dual purpose: Storage containers) to bail out the cabin if necessary. Eventually, I think I will have 2 electric pumps and one manual pump aboard the 25, as it's in the water and away from immediate assistance at this time- The mooring is about a mile from the nearest marina. As long as there's a charge on the battery and the wiring to the pumps is sound, I should be OK. I may try to install a sump and shower in the head compartment; Add that to the list of 'new boat projects'! ;o)--Jon BastienH23 '2 Sheets to the Wind'H25 'Adagio'
