A
alan
The largest openings I've needed to make were done with a 1/2" drill bit. Putting in a pumpable 5 gal porta-pottie. Plan on routing the hoses between the small storage area, aft of the head, and the wet locker. The pump-out fitting would go between the winch and life line. The vent would go through the vertical part of the deck aft of the port. I was going to use a circular hole saw (drill attachment) like the kind used to drill large circular openings in wood doors. Would that work well? I've thought about routing the sanitation hoses through the wet locker but longer run, would use up valuable storage space and the deck fittings would essentially be in the cockpit. Any thoughts appreciated. alanP.S. I have a '94 26
