How do you pronounce
Razl
Aug 11, 2005
1
- - Charlestown, RI
I know what the GPS term WAAS is and what it stands for but have always been sheepish to bring it up in conversation because I don't know how it is correctly pronounced. Or is it simple just repeating the letters W-A-A-S?
Jun 7, 2004
944
Birch Bay Washington
Wide Area Augmention System
For those who do not know: WAAS is based on a network of approximately 25 ground reference stations that covers a very large service area. Signals from GPS satellites are received by wide area ground reference stations (WRSs). Each of these precisely surveyed reference stations receive GPS signals and determine if any errors exist. These WRSs are linked to form the U.S. WAAS network. Each WRS in the network relays the data to the wide area master station (WMS) where correction information is computed. The WMS calculates correction algorithms and assesses the integrity of the system. A correction message is prepared and uplinked to a geosynchronous satellite via a ground uplink system (GUS). The message is then broadcast from the satellite on the same frequency as GPS (L1, 1575.42MHz) to receivers on board aircraft (or hand-held receivers) which are within the broadcast coverage area of the WAAS. These communications satellites also act as additional navigation satellites for the aircraft, thus, providing additional navigation signals for position determination. The WAAS will improve basic GPS accuracy to approximately 7 meters vertically and horizontally, improve system availability through the use of geostationary communication satellites (GEOs) carrying navigation payloads, and to provide important integrity information about the entire GPS constellation. I say "waas" just like it is spelled.
Mar 21, 2004
2,175
Hunter 356 Cobb Island, MD
My neighbor works at FAA on GPS
He tells me that they pronounce it as whaz with a long "a" sound. Ok.... Jim S/V Java
Jun 28, 2005
101
Northern Northern 25 On the Hard, Bradford Ontario
Pronounce Stanchion (sp)
What about Stanchion (sp?) how do you pronounce that?
