Thanks!No problem with how to wire or install,just can't find how to go from the bilge to the pump.No hole to route wire and no clearance from bilge to pump.To run under the floor the wire would be crushedIt doesn't really matter what kind of boat you have, the wiring is the same, unless you are asking specifically how to run the wires, etc. If you have one panel switch for the bilge pump, you just wire the float switch in line with the wires feeding the pump. The float switch itself is something that completes the circuit when water rises in the bilge and the switch floats. Therefore you just wire in the switch on one side (either positive or negative - usually the positive side). Cut one of the wires and then put the float switch in line by attaching each lead to one of the ends that you make bare after the wire is cut. If you have a panel bilge pump switch that reads off, on and auto, then you have to wire it differently to accommodate those switch positions. A third wire is then introduced from the momentary "on" position on the switch so that when that is thrown, the power will by pass the float switch and let power go directly to the pump. The switch is then put in line between the power source and the pump itself.
Hhmmm... on 323 there is a ground wire from the breaker panel to a keel bolt. It is fed through a conduit. Maybe 321 does not have that, though?...how to go from the bilge to the pump...(
I will try and remember to follow the path on our 321 this weekend float switch and will let you know....Thanks so much!Our 97 doesn't have any route out of the main bilge and to run over top and under the floor would crush the wires when you walk on the floor![]()
Yes it's through the breaker. That's my preference. I would rather do that than fry a wire if the pump jams. I just wired the float switch in parallel with the main pump circuit at the junction box. I don't agree with the logic of wiring the pump directly to a battery without some sort of protection. Leaving the pump breaker on is not a big deal. If you are concerned about the breaker being shut off, are latches available that would allow the breaker to trip, but prevent it from being switched off. They are often used in residential and commercial applications. Just my thoughts.Mmmm... Doug, isn't that lead in the junction only hot when you have the panel ckt breaker "on"? Mine is that way.
Yes it's through the breaker. I would rather do that than fry a wire if the pump jams. I just wired the float switch in parallel with the main pump circuit at the junction box. I don't agree with the logic of wiring the pump directly to a battery without some sort of protection. Leaving the pump breaker on is not a big deal. quote]
The logic of wiring to a battery- or off of the circuit breaker - also requires the logic of putting an inline fuse on the hot lead if not otherwise protected. I spec'd that in post 4. Again, maybe yours (and 321) is different, but when the bilge pump breaker is "on", the pump runs, and you don't need one of those on/auto switches (nor worry about leaving a breaker turned on when away from the boat). I believe some don't, as the pump also is the shower drain. Maybe that's why I moved the feed to the pump's shower switch to the fresh water breaker. You wouldn't be using the shower drain if you didn't have the pressure water pump on also.
