Mark
I recently bought and installed a depth finder in my '83 Mac 25. The transducer is a "thru hull" so I glued it in. I removed the access port (aft) in the v-berth, removed the numerous jigsaw puzzle foam blocks (that I can not get all back in to save my life) and epoxy mounted the transducer to the hull. It works like a dream while in the slip and while motoring out of port, but drops in and out while sailing. I am guessing that I am, while heeling or bouncing through waves, picking the transducer out of the water. I assumed that the loaction I chose would be ideal as it does not suffer the turbulent effects of the keel, etc. but I guess I was wrong. Any suggestions as to better placement of the transducer would be appreciated. I will not pop a hole in my hull and do not want to do transom mount...I don't want to know how deep the water is where I have been already!!-Markp.s. Oh yeah, anyone have any idea what the rope is that seems to stradle the keel. A knot on either side of the keel cable at the rear bulkhead and a loop passthrough at the front bulkhead (just aft of where I installed the xducer above). My engineering mind can see no reasonable explanation for this rope...help please!!!
