How confident are you in your boat's 120v wiring?
Sep 24, 2018
4,823
Catalina 30 MKIII Chicago
Therefore, it makes it even more ESSENTIAL to confirm the stability and continuity of the entire system. In most cases, the wiring, even if old, is rarely suspect, but worth a check. How? When REDOING the connections which are ALWAYS worth removing and reinstalling, look at the end of the new bare wire you expose for the new connectors. Any green? Then work your way back until you find clean bright wire, or replace the wire while you're there.
:plus:
MFD
Jun 23, 2016
306
Hunter 41DS Pacific NW USA
Shore power plugs that are loaded near their rated capacity have a disturbing frequency of overheating, resulting in failure. I would make certain my shore power was rated for at least 50% more than what the heating system drew. Same with AC.
I believe electrical codes say to run at 80% maximum for continuous loads, where a continuous load is anything greater than 3 hours.
So for a 30A shore power connection, that would be 24A.
Obviously less is even better.
I have seen a couple near misses with burned/melted wiring on boat shore power connections.
Both were liveaboards with space heaters and things 'tuned' to not quite trip the 30A circuit breaker.
  • Helpful
4,068
Corsair F-24 MK I Deale, MD
That 80% figure is for breakers and hardwired circuits. A shore power cord that may be wet, with salt between the prongs, is a different case, although there is nothing in the code. Just experiences.
Likes: Timm R Oday25
MFD
Jun 23, 2016
306
Both the ones I saw, the burned/melted wiring was inside the boat, not at the actual shore power connector itself.
One at the wiring near the panel itself where the 30A came into the panel, the other at a separate 30A circuit breaker before the panel.
One a ~15 year old Beneteau sailboat and owner said all was 'unchanged/as-built' from the factory.
The other a 40+ year old (not sure on model) sailboat.
I didn't look close or ever find out about root cause for either.
Most of the ones I read about (or see pictures of) online are at the connector itself which seems more common for obvious reasons.
I have seen some burnt/black pedestal connectors at guest moorage slips in the past. Did not use, notified the marina.
This was posted back in February 2019. I visited the Marina office in Vancouver BC. Right by the door they had this board of memories.
Sep 24, 2018
4,823
I used to have a slip at a marina that had a board like this. 30A can do a lot of damage. I installed a 30A circuit in a garage once. Late at night I pushed a ladder a little too hard and the 1/2" conduit pulled out of the box. Subsequently the wires pulled out and shorted out against one of the boxes. Then the box caught on fire. I was blowing on the flames while concerned about burning my face and the garage. Luckily, both survived without harm. I immediately bought a fire extinguisher and reworked the electrical
JBP-PA
Apr 29, 2022
838
Jeanneau Tonic 23 Erie, PA
The boat is usually dead cold. My boat shoes are usually ice cold as well. I might buy some heated socks because the floor is freezing! Every so often it gets the the point that I can't feel my toes! Heated mats take forever to heat up but then again, mine was only 120 watts.
I was running a 25' and a 50' 12 gauge, heavily insulated cord. A few times left it out and snow would cover them. I found it a bit humorous (although not exactly safe), that the snow would melt around the connection point of the two cords. I suspect broken wire strands and/or poor connections due to wear and tear. The cord leading into the boat had three outlets. One or two would be for lights and the other would be for the heater. I tried my best to keep the high load run short. On jobs where we have hand built extension cords with quality connectors and industrial grade portable cable, we rarely feel the ends get warm, even when it's loaded up.
I have a pair of down booties. They are cheap and do an amazing job of making you feel warmer when the floor is ice cold. I put an old pair of foam insoles in them because the down underfoot compresses and loses insulation.
