I recently had a Legend 40 surveyed and all went pretty well except for these two rusty cracks in the hull/keel joint. One wraps around the trailing edge of the keel about a foot on either side, the other is on the port side a 1-2 feet behind the leading edge of the keel. There was a small but steady stream of clear(not rusty)water draining from a spot on the port side of the rear crack for the duration of the short haul(about 40 min). There was no water in the bilge. How concerned should I be? Clean it, seal it, paint it and go on? Or would this require dropping the keel for a full inspection, rust remediation and sealing procedure?
