Mark Waggoner
For the last couple of winters, I've tried to be conservative on anti-freeze and have tried draining the hot water tank instead of pumping it full of anti-freeze. This has been a real pain. the drain valve of the hot water heater is so low that I can not fill more than a cup at a time, empty it, again and again. If I just let it drain, will all of the water make it to the bilge. I would not want water to freeze under the fuel tank, which is where the hot water tank would drain to. Has anyone found a better way. Thanks
