IMHO
I have a 1978 33' (shallow draft). Realizing that everything in life is a compromise, I have found this boat to be the best combination of what I needed.
I lived aboard her during one of the worst winters in Philadelphia. With the addition of a Dickinson propane heater I stayed warm...and dry. There was room...and room enough. Yes, you can always suffer from "foot-itis." A longer boat will have "blagh, blagh, blagh. It does...and it will cost you.
I replaced items as they failed, and used the best replacement parts that allowed me to do the work myself.
I have been told that you cannot kill the original 2QM15 engine. God knows I have tried...without success.
From my friends that have the same boat the common problems are few.
The packing in the rudder post has aged by now. If it has been replaced recently you will leave this earth before it needs to be done again. If not water will "blow" past the failed packing and drain into your bilge.
Original toilet ain't worth...well you know.
Kenyon stove should have been replaced.
Cushions far to thin and degrade over time.
Hull lining ALWAYS need to be replaced from the original.
Ice box so badly insulated that you would have better luck with a sock.
Plywood "holly" floor should be looked at closely.
Original electrical panel works well but, is sometimes replaced or, moved and replaced...nice touch if this has been done
By this time original ports (opening) have run thier race and need to be replaced.
Original lifelines were nylon covered and have now streached and aged. Replacement is warrented.
I have the original CDI furler. Works like "butta." CDI says there is no replacement period. Use it, and use it hard.
You should expect upgrades on electricals. New is better....newer is almost mandatory.
There were four seacocks (sink, toilet (raw water), toilet (waste), and engine (raw water). Original were gate valves. They should have been replaced by now...or should be.
Original boarding ladder may be near its' useful life. The attaching bolts will simply fail when you least expect it.
Original aluminum tank will have pin holes by now. It should have been replaced.
Because of the nature of the contents, my water tank is still clean and water tight.
I am at the Annapolis Boat Show each year. Nothing comes close to what I already have. I am a fifty-six year old guy with a thirty seven year old mistress.
Sure beats the hell out of a hole in the ground in Iraq.
