I really, really like mine
First, some background upon which to qualify my opinion:This is my first boat. I have had it since Memorial Day 2001. I took an ASA sailing course at LightHouse Landing in KY in the middle of May, before which I had never sailed. I will say that the course and instructor provided me with a **great** foundation upon which to build.>> looking at the smooth round bottom and big main sail, is it tender in gusts?I have found the 212 to be quite predictable and managable in gusts. I'm still getting a feel for the boat but it doesn't seem tender at all. It also sails well under mail alone, BTW.>> 2300 lbs for boat and trailer is pushing the limits of my tow vehicle, what's the real expected tow weight after motor, fuel, and gear?I don't have a tow vehicle at all but, obviously, it depends on how much gear, etc. You should be able to approximate most of the weights pretty closely and you should be able to get a good bit of the gear off the hitch and into your vehicle.>> How easy is it really to rig? Is the mast raising system needed? How tall is the mast? I can raise my 17' daysailor's mast easily my self with no raising apparatus (don't know the length of the mast off hand).I'm not sure what the mast raising system is, exactly. I assume it is a winch and cable attached from the trailer to the mast. The mast is 31' (from the waterline, I think). The dealer took me through the raising process so there were two of us. I have the roller furling jib and we had to push a bit to get it attached. I will fully investigate a mast raising system (Hunter's or my own) before I get into trailering, if only for convenience. Otherwise, getting the mast up is a pretty straight forward operation without a lot of complications.> Any feedback would be greatly appreciated.The more I sail her the more I like her. I have a lot to learn but I couldn't be happier with the boat. You are probably right in thinking about the 212 for your stated needs. Find a dealer or owner that will let you test drive it.Good winds and happy sailing,Steve
