Ballpark Adjustment
The basic Loos gauge comes in 2 sizes, for wire 3/32 to 5/32, and 3/16 to 9/32. The only 260 I have helped with had 5/32 wire, but even though I have the 3/16 gauge for my H-26 wires, we tried it on the 260 rigging, and it showed that the tensions were way off.Accuracy? For about $50 you may not get fantastic accuracy, but I completely trust the repeatability of the measurements. That is, I trust the gauge enough that if all my sidestay readings are the same I know I have the rig balanced side to side.If anyone has a private aviation mechanic as a friend, the guy should have a sophisticated dial gauge tension meter you can borrow. Most smaller aircraft and commercial aircraft have lots of wires in the controls, and the tension on them is checked and adjusted regularly. Unfortunately, those gauges are in the hundreds of dollars, if not more.
