Marine Traveler toilet isn't new...
It's been around for decades and is a very popular system. In fact, the bowl assembly the same one as the VacuFlush, but without the pedestal assembly. The only downside to it is the size of the tank footprint--about 19" x 20"...it won't fit in a small head. If it'll fit in yours, go for it (Defender has a MUCH better than WM, btw). However, there are a couple of things you need to know about it: it can use AS LITTLE AS 1 pint/flush, but that doesn't include any water you'd add to the bowl ahead of solids (that's done by lifting the flush pedal), and it's not always enough to send all the TP down the hose or especially erase skid marks. So in actual practice it uses an average of about a quart a flush--about half that of a manual marine toilet. Meaning that 9 gallon tank holds only about as many flushes as an 18-20 gallon tank connected to a manual marine toilet. if your existing holding tank is aready that big, you'd only just come close to doubling your current capacity. Which means I wouldn't put a y-valve in the line between the Traveler and a larger holding tank...'cuz you wouldn't gain anything with it.Another issue is the size of the larger tank. That one has to be a multiple of 9-11 gallons. Why, because the Traveler Tank holds 9 gallons... As long as your larger tank is 18-20 gallons, 27-29 gallons etc, no problem...it'll hold two Traveler tankfuls with room to spare. But let's say your larger tank is 16 gallons. You move the contents of the Traveler to it once, leaving a remaining capacity of only 7 gallons more. Same thing would be true if the larger tank is 24 or 25 gallons...it'll hold two Traveler tankfuls, but not the entire third. So either you'd have to be VERY good at knowing when to stop the macerator before the second tank overflows, or lose almost a third of its capacity because you're afraid to risk it. I'm not trying to discourage you from buying it...it's a great system. But if you think it could almost give you the equivilant of a 50 gallon holding tank connected to your current toilet, you'd be very disappointed.
