Peggie THANKS!!!
Thanks very much for your detailed reply. Unfortunately it is an old European toilet base, with a 4" discharge, that used to have a water tank overhead. The toilet is very old and is a detailed flow blue painted bowl inside and out. We have a 1925 36' classic yacht which has been fuly restored to it's original beauty with the exception of the head (I don't really know what was originally used!) I know that this is not the classic yacht forum, but I have read some of your articles and other knowledgable individual replys and I wanted to get your, and other respected, opinions. The boat has spent her entire life in Vancouver BC and does not have a holding tank, only direct overboard disharge. I have the boat in Seattle now and need to redo the entire system, so we went off looking for a head that would fit the era theme. My wife, an antique collector, found one, only not at a marine supply house! Your idea of the 1-2 gal water tank over the base is a good idea for the flush volume. The fresh water system on the boat is gravity feed, so I would need to get the water up there somehow?? Since there would be some water left in the bowl, using fresh water may be preferable to raw water, but I'm not sure how to get the correct amount in the tank?? Another issue is the treatment system. I really don't want to start cutting pump-out holes in her deck and would like to go with a treatment system. It could be located within 2-3 ft from the head and will have a 3-4" drop to the area. Is there a treatment system that you recommend? Also, if you have any other suggestions on the European toilet dilema, please let me know. If it could work, it would be a real beauty!!!Thanks again, Garry
