House Battery Circuit Troubleshooting
Mar 26, 2008
8
Hunter 45DS Greenwich Bay
I just had an issue where I lost DC power to the main DC switch panel in my 2013 45DS one week after launching. I found that I still had a connection to the charger/ inverter so it reported the battery bank voltage and could generate AC power with the inverter. I also discovered that the bow thruster worked. I naturally went looking for fuse connected to the battery bank and found a nice big 300A fuse under a clear cover in the battery compartment. It was a traditional link fuse and was unbroken. I could not find any other fuses between the batteries and the DC panel.
That night I located wiring diagrams on the Marlow-Hunter website here: https://www.marlow-hunter.com/wp-content/export/ (the link provided in the Ask a Hunter Owner Forum is broken). There were two battery circuit diagrams that indicated that there were indeed 3 fuses located in different locations depending, I assume, on the model year. The fuse I found was only for the bow thruster. After over an hour of searching for the same type of link fuse in all the locations on the diagrams, removing the switch panel and wall section underneath, I noticed that there were two white squares under two of the three positive cable connections to the terminal block in the battery compartment. There was a label on the side identifying it as a 300A Bus fuse. I had never seen a terminal fuse before. There was corrosion on the top of the fuse under the cable connector which probably resulted in a poor connection and not an over current condition. I imagine there are several Hunter models that use this fusing technique so I thought this post would be helpful to others troubleshooting a DC issue on their boat.
May 20, 2016
3,015
Probably a MRBF (Marine Rated Battery Fuse). Squashed cube shape. Very common for protecting cable sized wiring. The other may be an ANL. You should stock spares for each type
Les
Jun 1, 2009
1,845
Hunter 49 toronto
Not a big fan of these fuses .
They are ideal as a temporary solution to retrofit something, but not as permanent install.
This would be for the very reason you saw: a bit of corrosion, and all bets are off. Also, very difficult to test without removing.
Also, extemely dependant on how you tighten the nut, etc.
These are good for small runabouts, where you don't have a lot of space for proper fuse blocks.
I am reasonably confident that Hunter didn't fit these, although I've been wrong before.
You might look at replacing these
May 20, 2016
3,015
@artboas I disagree MBRF are great fuses - they are so much easier to replace when it is rough - Getting within 8" of the batteries is very hard - these fuses do it!! They are no harder or prone to corrosion than a normal battery cable hooked up to the battery. They are just as easy to test as any fuse - just measure the voltage drop across the fuse....
Les
Jun 1, 2009
1,845
Hunter 49 toronto
Les,
I hear you, and understand your opinion
These work fine up to a certain size of boat (in my opinion)
I'm happy to make your acquaintance, and wish you wonderful & safe sailing
Likes: LeslieTroyer
