In my research on wind generators it seems a dump or shunt is needed, for when the batteries are full.
I can not imagine putting a big honking resistor in the engine room to absorb this excess energy and heat everything up.
What about connecting it to the hot water heater element? I have the Raritan 1125 ohm element for 110 volts A/C. I have seen 12 volt elements to use in this way for sale on the web, but is it really necessary to have a 12 volt element? Isn't it just a big honking resistor and even if it didn't get as hot as a 12 volt element, it should consume the excess energy and give some heating?
Thoughts? Thanks.
Thoughts? Thanks.
