Hot Water Tank
A
Adam F.
I just purchased a 1982 Hunter 33. The hot water tank (6 gallon) needs to be replaced. Who makes them? Where can I get one? af.
Dec 2, 1999
15,184
Several Mfgs.
Adam: There are several mfg but I think that most of the Hunters had Seward water heaters that are available at almost any marine supply stores. If you use the same brand you will save yourself a lot of grief with any re-routing of plumbing. I think that they are on sale now from several of the catalog stores.
Rafi
Try www.sailnet.com
It is probably made by Seaward. Try www.sailnet.com under plumbing. Last time I checked they had 4 different 6 gallon models listed. Make sure you get the one you currently have. Good luck.
K
Ken Palmer
What's wrong with the original?
Do you really need to replace it? Is it leaking, or just stopped working? Is it heated with only 115 VAC, or also with engine cooling system? Ken Palmer, S/V Liberty
Peggie Hall/Head Mistress
Unless it's leaking...
It's prob'ly repairable...and the good news is, there aren't many parts that can fail, and those don't cost much.. What's wrong with it?
