Jack
The metal housing on the hot water tank is rusting. Is there a fiberglass liner inside? I would believe that this is a common problem for salt water boats and that rust on the outside of the metal tank is not a huge problem or the manufactures and builders would install ss tanks but I have been wrong before. What are your thoughts? thanks, jack p.s. It works fine both ways, electric and off the engine. thanks again, jack
