John
About a week or so ago I posted a question about my hot water heater. Well, I removed it from my boat and it is a Atwood which is also labled Seaward 6 gallon. when I took it apart inside the galvanized box is a 6 gallon aluminum cylinder. When I flushed it out a LOT of sediment came out of the fresh water side. I am going to reinstall it as it appears fine with no leaks. I have wire brushed and cold galvanized painted the outside and improving on the original insulation which was just 1/2 inch fiberglass. I don't intend to reuse the sheet metal box. I am also covering the electrical connections with a pvc electrical box. I will also be replacing the engine hoses to and from the heater. Is there anything else I haven't thought of?
