K
Kevin Muhlendorf
I'm finally wet this week, and started testing out all the systems in the 85 Hunter 31 I bought in December. First thing I noticed when I plugged in the hose to check the fresh water system (I was careful to make sure the pressure wasn't too much) was that the water started pouring from the front of the hot water heater (under the galley sink). Same thing happened using the pressure water from the tank. Upon further inspection, the water heater is definintly rusted through. West Marine has a force-10 6 gallon hot water heater for 269 - I've looked online and its cheaper at 229-239 elsewhere, but with shipping,I figure its a negligible difference. Question is, how dificult is that to install, especially given the connection to the engine's cooling system?
