Engine starts fine but after sailing, it ddn't restart. I get the oil pressure buzzer as usual. But no clicking solenoid, no slow grinding, nothing. Voltage and amperage are ample. I dropped anchor and tried several times. Wiggled and tugged wires to see if there might be an intermittent connection. Tapped a hammer on the solenoid to free it up if it was sticking. Eventually it started but I have no clue as to why.
My guesses are the solenoid or corroded wire. Any help on where to start to narrow my search. There is no key, just a switch to activate the system and a button to start. With the switch on the oil buzzer and light activate and guages respond. I never get a slow cranking, even in this no-start scenario. Once it worked, it cranked fine.
Engine is an old Perkins 4.154 that runs great.
