Hot Plate Ring Stain
Jun 13, 2010
70
Hunter 1994 Hunter 35.5 Legend walker, mn
I bought a 1994 Hunter Legend 35.5 and there is a hot plate stain(ring) on the counter....first off, what kind of material am I dealing with and secondly, is there a process to remove that stain...thanks for any help....craig
Jan 24, 2017
671
Hunter 34 Toms River Nj
If the counter surface is corian you should be able to sand it out with sand paper then polish it with a scotch brite pad. You should contact Hunter and see if it is corian or not. Most likely it is, lots of builders used this in boats.
Hope this helps
