hoses on hot water tank
40
macgregor 26M Macgregor 26M newcastle
quick question guys. Which is the hot water hose of the two hoses coming out of the hotwater tank. Tried tracing them but next to impossible. 1982 gas Atomic 4 30 hp. Russ
Jan 6, 2010
1,520
Russ,
With the little info you gave, an idea would be to turn on your 110VAC and let the tank warm up.
When done, turn on a spigot and feel what hose gets warmest. Hold hand about 6-8" away to make sure.
CR
Jan 1, 2011
27
catalina 350 Noank
cold water goes in low hot comes out higher. Some have hot and cold stamped next to outlet in little letters on the flange. On mine there is a diagram on the side next the the wiring showing the wiring and shows hot and cold lines labeled.
