Trailer For O'Day 22
I have had my O'Day 22 for 29 years. Its still on the orginal trailer! I use the trailer only to drag the boat 4 miles to the launch and retrieve it in the fall. I never exceed 25 mph and use automotive compact spare tires! The trailer is not galvanized and as result I have had to spend upwards of $1000 to reweld and etc. Still its been cheaper to repair rather than replace. I don't know that you will find a new "ready-made" trailer for your boat. I suggest you shop the boat dealers in your area and look for a good used galvanized trailer with at least a 2800 to 3000 lbs. capacity. Then find a local small welding shop, they should be able to fabricate the necessary supports. I have taken measurments "off" my trailer & would be glad to send you a copy. Contact me atskyking22@aopa.netGood Luck!
