Hose replacement
Feb 25, 2014
95
Catalina 30 Grand Lake. Wyandotte, Ok.
While checking everything out in the boat's interior I found that the cockpit drain hoses are oozing water out of them. What type of hose should I use? Will radiator hose work. These are not below the water line and have no heat or pressure. What do you guys suggest?
Wire reinforced hose. A friend used cheaper hose, then switched back.
