Back on 8-27-04 I posted a message “Yiks, almost sank the boat”. Well I have finally had time to take the advice and fix the leak before the next big trip. I put a jack under the front of the Keel and put a small amount of pressure on it before loosing the bolt inside the cabin. Well the keel kept moving up as I raise the jack? Well the keel finally stop raising and I had a small amount of weight on it. I then climbed up into the cabin and the bolt was standing about 1.5-2” above the plate. Don’t know how much tread is on this bolt but I would have to think that was very close to the end!!! Then the terrible thought of that bolt walking itself out 10 miles out in the gulf with 4-5 ft wave scared the SH#@ out of me. I got a good bead of 5200 under the bolt and tightened it down. I also put a good bead around the compression post. Hope to put the boat in the water and check out the leak before the yearly trip to the Texas cost. I guess this is something to keep an eye on in the future!!Thanks Dale
