Hooking up knot meter light
Jason Patterson
On the back of my knot meter there is a terminal that says light. Is there a light in the knot meter? If there is where is the ground? Can someone help me out? Thanks Jason (H23 Slapshot)
Jeff Peltier
Most likely any mounting
screws or brackets would go to ground.
Jason Patterson
Make of the meter
The knot meter is a SR Mariner made by SR Instruments. The boat is fiberglass so I can't ground it to the case. Do I run a ground from the case to the battery or where? Can someone help please? Thanks Jason
Bill Murray
electrical or mechanical?
IS this an electronic knot unit or a manual one? Does it have wires that go to a sending unit or a gear driven cable? If it is electrical, the lamp probably uses the same ground that supplies power to the unit. If it is mechanical, you will need to find the lamp installation and see where the grounded part of the socket (the outside metal part that surrounds the lamp base) is wired. good luck Bill Murray
Jeff Peltier
ground back to the battery
Yes, you have to run a wire from the grounding part of the indicator back to the battery or catch an other 12 volt grounding wire near by. Jeff Peltier
Jason Patterson
I got it to work!!!!!!
Thanks everyone. I got the light to work. Happy sailing Jason (H23 Slapshot)
