tony giaccio
5 yrs. ago replaced hood furler drum.delran bearings apparently were faulty,they replaced w/ stanless steel bearings.never changed the line,angle of feed is correct,i flush it religiously.problem---seizing up when unfurling as well as furling.when i reverse direction it clears the problem w/hard pull.tends to happen twice per use.WHAT should i look for? what should do?
