Honter 33 2006 keel repair
Tomek
Oct 4, 2015
26
Hunter 33 Penetanguishene
I have gouged a tip of the wing on my wing keel. I believe the keel is lead. The gouge is about 3" long 2" wide and 1/2" deep.
What material should I use to patch it:
1. Lead? (if so, how to make sure it is firmly atached?)
2. Some epoxy or polyester resin with some reinforcement? (fiberglass or other filler?)
3. Just grind it to make it even, before repainting with anti-fouling paint (it is not big enough to make significant difference in hydrodynamics, I think)
TIA
Tomek
7,608
Alden 50 Sarasota, Florida
I'm interest in other opinions. My thought is it's more cosmetic than anything else and I'd simply grind it down for appearance sake. Wouldn't play with lead and any filler would likely be only temporary.
Tomek
Oct 4, 2015
26
Thanks Don, for your reply.
My thought as well, but also interested in other opinions.
I would fair it with epoxy/filler and then paint with anti-fouling paint after removing all coatings in the area.
Plenty of racing sailors have added fairing to their keels to improve the shape for better speed. This doesn't seem that different.
Jan 4, 2006
7,466
Unless you're worried about your tarnishing your rating as a world class racing sailor I'd fair it, paint it, and take off for a beautiful sheltered anchorage with a bottle of wine.
Likes: ggrizzard
-na -NA Anywhere USA
As a hunter dealer, I use to clean to include sanding the area out. Most 2006 Hunter 33’s were lead. Stick a magnet on it and if it does not adhere to the hull, it is lead. Then take two part epoxy recommending Water Tite. It is the most durable and is hard when dry. Wet sand to smooth out and apply anti fouling.
if cast iron, then sand and wipe down with acetone. Apply metal primer that contains zinc chromate and apply immediately to prevent the cast iron from oxidizing. Apply two part Water Tite, then epoxy barrier coats and finally anti fouling paint
the drawback with Water Tite, it needs to be 60 degrees and it a 24 hour cure.
