Honda outboard problems
Mougly
Jul 14, 2009
59
Sonic Sonic 23 Barrie Marina
Hello all
I seem to be having a problem now with my outboard, I noticed what looks like an oil leek but am unable to find out where it is coming from..the oil pressure indicator light is on as it is supposed to be, but I get oil or maybe gas going into the water when the motor is started, yesterday the motor just shut off while I was heading out (lucky for me there was enough wind to get us away from the rocks :Liar: ), after that the motor started and worked fine.
any suggestion ..the motor is a 1991 Honda 7.5 HP 4 cycle long shaft....
Beneteau 323 Annapolis MD
I had that on a 7.5. The fuel pump diaphram leaked both ways, mixing oil/gas.
zeehag
Mar 26, 2009
3,198
used to have an 8--could not pull it to start--sold it for 1000 and bought a brand new nissan--had absolutely ZERO problems with it--traded it for a smaller engine by nissan----stilll having fun without problems----goood luck...~~~~~_/)~~~~~~
caguy
Sep 22, 2006
4,004
It is most like gas leaking from the top of the carb. On the Bf100 there is a small hose that runs from the top of the carb to the bottom of the compartment. If the gas is coming from there then you likely need to have your float adjusted. You can tell if when you squeeze the bulb on your gas line the gas drips from the bottom of your engine compartment. You might also want to check the fuel line running from your fuel pump to the carb.
