I was completely surprised (in a good way) today. I finally broke down and purchased a Honda EU2200i Companion generator. My primary motivation for this was to provide the ability to charge my battery bank while on a mooring using my Pronautic 12-30P charger instead of running my engine. It appears that I might be the beneficiary of Honda's increasing the upper limit on its 2K generators to 2.2K.
I fired up the generator and connected it to my main AC Dockside input using the 30Amp plug on the Companion. Without a second generator, the 30 Amp plug is rated for 15 Amps and 120 volts continuous (1800 watts). While the units maximum output is reported to be 2200 watts, the manual states that the 30 Amp plug is limited to 1800 watts unless it is combined with a second unit. Thus, I was expecting my Battery Charger to be limited to 15 Amps even though it can max at 30 Amps. The incoming voltage dropped to 90 volts and the Battery Charger went to 21 amps. I noted on the Promariner manual that there is a setting to reduce the maximum input to 25%, 50%, or 75% in cases of reduced incoming voltage. I need to check with Promariner in the morning to see if running the unit at lower than expected voltages will do harm or whether I should reduce it to 50% before I leave the dock on my trip.
Then the surprise. I knew my 16K Air Conditioner only drew 7.5 amps when running according to its specs but there was no surge rating. I fully expected to trip the breaker when the compressor kicked on. Didn't happen … the air conditioner ran great. The generator had to run at a higher RPM but the units ran great.
I need someone to burst my bubble and tell me what I may be doing wrong because this appears too good to be true. I sense that I need to find out what level of voltage is running into my Air Conditioner but it has a low voltage threshold at 85 volts and that didn't trip.
However, if I'm not doing anything wrong … the Honda EU2200i Companion has a new home on my boat. At 47 pounds its lighter than my kids' suitcases on vacation and easier to carry.
Go ahead … somebody mess up my good mood … please ...
