H
HAL
What to do?
We have a Honda 9.9, 2005 long shaft ,with Power Thruster that will reach only 4500 rpm wide open.
Honda says 5000-6000rpm is were its supposed to run. We didn't have a tach before the Power Thruster, so I don't know if the Power Thruster might some how be responsible.
More details are: H260,lightlly loaded maybe 6000 lbs, centerboard down, speed 6.2 mph with reverse course for compensation, motor mount lowered 2” for more rough weather and backing bite, hull clean, 2 props, 9 1/4 x 8 and 6 1/2 x 10 with no rpm change ,tach reads 950 at idle which seems right.
Many have said a 9.9 will easily push this boat to hull speed ,which I guess is about 6.2 mph at 3/4 throttle. Normally you would go to a prop with less pitch to raise rpm, but Honda only makes one lower at 9 1/4 x 7 which wouldn't raise it 1000rpm.
I worry about carbon build up at low rpm and low hull speed unless throttle is wide open. What are we missing ?
