It depends...
A lot depends on if the Honda you are considering is a four stroke or two stroke. Look in the archives here for lots of opinions on the pros and cons of each. Short answer: DO NOT put a four stroke engine on an outboard mount that is not specifically designed to handle it. Based on the 115 pound weight you mention, I assume the 9.9 you are considering is the four stroke. The additional weight is not the only consideration. A four stroke generates more torque than a two stroke, and can distort, bend or even rip off an inadequate outboard mount. I think the boat would be fine with the weight of the engine if you don't mind it. One of the main reasons I went with a new two stroke last year (Nissan 8hp long shaft for my Oday 23) was that I couldn't see my wife handling the extra weight if she had to raise or lower the engine. New two strokes, while not as clean or as quiet as a four, are miles better than they used to be. For me, the chief advantages of the four (greater fuel economy, quiet, clean) were more than offset by the disadvantages (extra weight, extra cost, would also need to install new mounting bracket).
