BF8 fuel consumption
I ran a consumption test last fall on my 1998 Honda BF8 8HP outboard to get an idea of how much fuel I would need for my Havre De Grace trip in the spring.Test parameters: Boat - 27', 7000 lb 3'9" draft Hunter. Also the boat has an inboard diesel, so there is a big three blade prop underneath slowing the boat down. I intentionally filled my water tank and left my fenders on. My BF8 has the standard prop - three blade roughly 9.25" x 8.6" - not the powerthrust prop. I can get to about 2/3 throttle with the prop, the boat just doesn't go any faster if I give it more gas, the engine just bogs down. I filled my spare 3 gallon tank with exactly half a gallon at the gas station. I left my marina using my normal 6 gallon tank and headed out to the river. I disconnected the 6 gallon tank, waited until the engine was about to die and plugged the hose into the 3 gallon tank and immediately set the throttle at about the 2/3 setting. I ran exactly 35 minutes when the engine died.I found later back at the marina that the 3 gallon tank still had at least four or five ounces left in the tank that the pickup tube couldn't reach.I'd venture a guess and say you would get even better results with your boat, maybe 3/4 gallon/hour going at a good clip, but to be safe budget 1 gallon/hr.Mannyedited to add - I forgot to mention it's a four stroke
