David King
The cooling system on my 2000, 8 hp Honda 4 stroke outboard has a nasty habit of clogging up with salt. I check the outflow every time before leaving the dock and several times, water was just dripping out. I use the boat in salt water, but the engine is raised when sailing or at the dock. I usually sail every week year-round, but there are times that I have to keep it at the dock for a few weeks at a time. If it is clogged, I have to clean it out by back washing with a fresh water hose through the outlet port. One time, I had to take it to a dealer to get it flushed out. The owners' manual says something nonsensical like removing the prop, starting the engine, and using a special fitting to fresh water wash the cooling system after every use in salt water. Has anyone else had a similar problem? How did you handle it? David King "Molly"
