I just bought our first sailboat - 1978 25' Hunter. And after taking her out a half dozen times and fighting the head sail up and down, I decided I needed a roller furler. Yet the cost of a furler system right after our boat purchase made it a tough nut to swallow. So after some research online, I found a few sites where people made some homemade roller furlers and decided to try it on my own.I used 3/4" & 1 1/4" sch 40 PVC with a SS washers on top at the eye swedge and at the bottom where I put a adjusting nut on the top threaded pin of the turnbuckle.At the hank points I used PVC couplers on the pipe and notched out so the hank could be inserted just enough to grab the forstay.I still need to add (1) 1 1/4” PVC coupling just below the roller drum. I had to cut out a section, it was too high up the forestay at the top of the mast and the spinnaker & jib blocks wouldn’t let it spin. But now I have approx 8" of "free" forestay above the top of the PVC and the swedge at the eye.** Is this too much? ** Do I need to add a section at the top to fill in the space for a more snug fit?** Should the roller be closer to the deck, or do I need just enough space on top for it to be able to furl/unfurl freely?I still need to add the blocks and rollers on the deck and rails for the furler line and add the jib sheets. Just has a single line now to hold the sail in place in the meantime.It unfurls and furls back up very nicely, I ran it in & out 4 or 5 times, the last 2 were great, the wind was picking up and it tightened the furl nicely. It has yet to be tested on the water.Parts Used:(4) 10’ x ¾” PVC Pipe(12) ¾” PVC couplings(1) ¾” PVC plug - (top end termination)(1) ¾” x 1 ¼” PVC bushings(1) 10’ x 1 ¼” PVC Pipe (14” total used)(4) 1 ¼” PVC couplings(1) 1 ¼” PVC plug - (bottom support termination)(2) 4” ABS caps(3) 1 ¼” x 5/16” SS flat washers(1) ¼” SS fine thread nut Total Cost: $47.90Any/all advice or comments, (good or bad), will be appreciated.Pictures @ link below.Thanks,JeffS/V Winter Fox
