tom
All of this talk of diesel has me thinking about biodiesel. I read a short paper on making diesel from waste oil from restaurants. Seems like a pretty simple procedure. You take methanol and react it with lye (sodium hydroxide) then you add this mixture to dry oil. After the reaction the fat(oil) is turned into an ester of methanol and a fatty acid from the fat. The glycerol and excess methanol settle out. Supposedly you can then use it directly in you diesel. It doesn't seem nearly as hard as making a good batch of home brew beer. Animal fats?? I guess that you can save your bacon grease and use it the same way. Any kitchen chemists out there making their own diesel??? Results and things to be careful about would be appreciated. You can also use clean vegetable oil directly if you mix it with diesel but it can cause deposits on your injectors. I'm tempted to buy a can of draino and a 5 gallon pail of soybean oil and see what happens. Supposedly if the biodiesl is made with cornoil your exhaust smells like popcorn....that would be a pleasant change.Tom
