Home Depot Foam
James F. Girgenti
Is it ok to use window type insulating foam in the bilge? Does it provide the same flotation as the marine two part type?
Timm Miller
Nope
It is not "Closed Cell Foam" it will absorb water...........West Marine has a two part system that is closed cell
MArk
Foam test
James, I agree with Timm. Standard expanding insulation foam can get waterlogged. Here's an experiment you can try at home: 1. Make a 6" or so blob of foam. 2. Let it dry for a week. 3. Weigh it. 4. Keep it submerged in a bucket of water for 30 days. 5. Weigh it again. Weight in step 5 minus step 3 is due to water saturation. To meet CG requirements, foam must not lose more than 5% of its bouyancy under this test. (see link) Happy (fusion powered) sails *_/), MArk
James F. Girgenti
Foam
Thanks for the advise. I will make a trip to West Marine.
